path: root/cpukit/include/rtems/score/chainimpl.h (follow)
* score: Add node to insert to Chain_Node_orderSebastian Huber2021-11-231-4/+7
| | | | | | This allows to use additional members of the nodes for comparision. Update #4534.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-2/+3
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* Remove *_Is_null() inline functionsSebastian Huber2020-10-141-17/+0
| | | | Simply compare the values against NULL.
* doxygen: score: adjust doc in chainimpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-106/+117
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Remove superfluous include from chainimpl.hSebastian Huber2019-01-071-1/+0
* score: Debug aid for _Chain_Extract_unprotected()Sebastian Huber2018-09-101-0/+2
| | | | Ensure that a chain node is not off chain while doing the chain extract.
* Remove make preinstallChris Johns2018-01-251-0/+1123
