path: root/cpukit/include/rtems/score/atomic.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-1/+1
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+156
