path: root/cpukit/include/rtems/score/assert.h (follow)
* doxygen: score: added dox in assert.h according to doxygen guidelinesAndreas Dachsberger2019-05-131-0/+20
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+108
