path: root/cpukit/include/rtems/score/apimutex.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-1/+4
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: score: adjust doc in apimutex.h to doxygen guidelinesAndreas Dachsberger2019-05-131-5/+7
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-5/+5
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+109
