path: root/cpukit/include/rtems/score/apimutex.h (follow)
* doxygen: score: adjust doc in apimutex.h to doxygen guidelinesAndreas Dachsberger2019-05-131-5/+7
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-5/+5
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+109
