path: root/cpukit/include/rtems/scheduler.h (follow)
* config: Simplify clustered scheduler configurationSebastian Huber2018-03-121-18/+90
| | | | | | | | | Do not use names derived from scheduler implementation details. Instead use names derived from the scheduler configuration or documentation. Provide defines for backward compatibility. Update #3325.
* config: Remove RTEMS prefix from internal definesSebastian Huber2018-03-081-42/+42
| | | | Update #3325.
* Remove make preinstallChris Johns2018-01-251-0/+247
