This change requires an rtems-tools update for symbol generation.
Working architectures:
- aarch64
- arm
- powerpc
- sparc
No newlib TLS support but checked:
- i386
- m69k
Updates #4920
Updates #3053.
- Replace the linear object file symbol search with a binary search.
- Sort the object file symbols after loading.
Closes #3748
Tracking references lets us manage when an object file can be
unloaded. If an object file has references to it, it cannot be
unloaded.
Modules that depend on each other cannot be unloaded.
Updates #3605
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Adding a local symbol lets the relocator find local symbols referenced
in relocation records. The local symbol table is erased once the object
module has been loaded.
This is a merge of the RTL project.
