path: root/cpukit/include/rtems/rtl/rap.h (follow)
* cpukit/include/rtems: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* doxygen: Added subclasses to APIAndreas Dachsberger2019-04-041-0/+2
| | | | | | | Update #3706. RTEMS Application Loader, RTEMS Runtime Link Editor, Status Checks and Test Support
* libdl: Remove _t from all structures as this is reserved for the standardsChris Johns2018-04-121-3/+3
* Remove make preinstallChris Johns2018-01-251-0/+115
