path: root/cpukit/include/rtems/rtems/ratemonimpl.h (follow)
* rtems: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* rtems: Canonicalize implementation Doxygen groupsSebastian Huber2020-12-021-2/+4
| | | | | | | | | Rename Classic API top-level group from Classic to RTEMSImplClassic. Use RTEMSImplClassic as a prefix for the subgroups. Change the group names to be in line with the API group names. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: Rename Internal to ImplementationSebastian Huber2020-11-231-1/+1
| | | | | | Use a top-level implementation group to gather implementation related files. The use of "Impl" is shorter and matches with the *impl.h file names.
* doxygen: Restructured cpukit/include/rtems/rtemsAndreas Dachsberger2019-04-021-1/+1
| | | | Update #3706.
* score: Static Objects_Information initializationSebastian Huber2018-12-141-8/+0
| | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
* rtems: Move internal structures to ratemondata.hSebastian Huber2018-11-121-1/+1
| | | | Update #3598.
* Remove make preinstallChris Johns2018-01-251-0/+158
