brains GmbH.
The application configuration options are documented in
"cpukit/doxygen/appl-config.h". Since the application configuration
option defines are also present in multiple test program sources, the
"#OPTION" references cannot be mapped to a unique definition. Add an
anchor for each option and reference it to avoid the issues with the
multiple definitions.
Update #3994.
Mention that resetting the processor usage time of tasks has no impact
on the period status and statistics.
Remove no longer relevant RTEMS_NOT_DEFINED error status.
Update #4528.
Mention the type of the pointer in the parameter description. Use the
more general term "object" instead of "variable".
Update #3993.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
This type was deprecated in RTEMS 5.1.
Close #3596.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Separate the definitions related to watchdog ticks from the watchdog
structures.
Update #3598.
Update #3598.
The rtems_rate_monotonic_period_time_t typedef as no corresponding API.
It violates the POSIX namespace. A user can do nothing with it.
Close #3595.
The rtems_thread_cpu_usage_t typedef as no corresponding API. It
Close #3593.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Add a variable named "count" in rtems_rate_monotonic_period_status
structure. Revise rtems_rate_monotonic_get_status() for the postponed
job count.
sptests/sp69: Add in the verification of the postponed job count for
rtems_rate_monotonic_get_status().
Update #2795.
closes #2795
Three additional functions:
rtems_rate_monotonic_postponed_job_count,
_Rate_monotonic_Renew_deadline, and _Rate_monotonic_Release_postponed_job.
Four refined functions:
_Rate_monotonic_Activate, _Rate_monotonic_Block_while_expired,
rtems_rate_monotonic_period, _Rate_monotonic_Timeout.
Rate_monotonic_Control contains one counter for counting the postponed jobs
and one for recording the recent deadline.
Update #2795.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Split up the potential thread priority change in the scheduler
release/cancel job operation. Protect the rate monotonic period state
with a dedicated SMP lock. This avoids a race condition during
_Rate_monotonic_Timeout() while _Rate_monotonic_Cancel() is called on
another processor.
This gets rid of the pull in of <stdarg.h> via <rtems.h> via
<rtems/rtems/ratemon.h> via <rtems/print.h>.
of this patch set.
Use the default thread lock to protect rate-monotonic state changes.
This avoids use of the Giant lock. Split rtems_rate_monotonic_period()
body into several static functions. Introduce a new thread wait class
THREAD_WAIT_CLASS_PERIOD for period objects to synchronize the blocking
operation.
Close #2631.
Variables with this type directly used the _Timestamp_*() functions.
This type is superfluous since all operations with it are done via the
This was obsolete and broken based upon recent time keeping changes.
Thie build option was previously enabled by adding
USE_TICKS_FOR_STATISTICS=1 to the configure command line.
This propagated into the code as preprocessor conditionals
using the __RTEMS_USE_TICKS_FOR_STATISTICS__ conditional.
Move implementation specific parts of ratemon.h and ratemon.inl into
new header file ratemonimpl.h. The ratemon.h contains now only the
application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7948217
http://www.google-melange.com/gci/task/view/google/gci2012/8024203
http://www.google-melange.com/gci/task/view/google/gci2012/8015207
http://www.google-melange.com/gci/task/view/google/gci2012/7950206
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025204
http://www.google-melange.com/gci/task/view/google/gci2012/8025203
* rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/part.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c,
rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, rtems/src/partcreate.c,
rtems/src/partident.c, rtems/src/partreturnbuffer.c,
rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c,
rtems/src/taskident.c, rtems/src/taskissuspended.c,
rtems/src/taskrestart.c, rtems/src/taskresume.c,
rtems/src/tasksuspend.c, rtems/src/timercancel.c,
rtems/src/timercreate.c, rtems/src/timerdelete.c,
rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c,
rtems/src/timergetinfo.c, rtems/src/timerident.c,
rtems/src/timerserverfirewhen.c: Changed Objects_Id to rtems_id in
the public API.
* rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c: Factored out common code to ensure
consistent behavior between rtems_rate_monotonic_get_status and
rtems_rate_monotonic_report_statistics.
* configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuusagedata.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/types.h, rtems/src/ratemongetstatistics.c,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
rtems/src/ratemonreportstatistics.c,
score/include/rtems/score/thread.h, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Changed the configuration of statistics granularity to use just one
define.
PR 1462/cpukit
* rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemonperiod.c: Fine
tune previous patch after analysis in application.
PR pr1462/cpukit
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/include/rtems/score/thread.h: Fix bugs in rate monotonic
statistics.
* libcsupport/include/rtems/libio_.h,
libcsupport/src/fs_null_handlers.c: Null handlers are now const.
* libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create
semaphores on the fly.
* cpukit/libblock/src/bdpart.c: Fixed format specifier.
* cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h,
rtems/inline/rtems/rtems/support.inl: Documentation.
* include/rtems/irq-extension.h: Documentation. Added API for
interrupt servers.
* rtems/Makefile.am, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/intr.h,
rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/sem.h,
rtems/src/barrier.c, rtems/src/dpmem.c, rtems/src/msg.c,
rtems/src/part.c, rtems/src/ratemon.c, rtems/src/region.c,
rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/tasks.c,
sapi/src/rtemsapi.c: Convert manager initialization routines to
directly pull parameters from configuration table. Eliminate empty
routines sportted.
* rtems/src/intr.c: Removed.
score/include/rtems/score/thread.h, score/src/coretodgetuptime.c:
Make all Thread and Period Statistics use publicly defined types. Do
not leak the SuperCore Timestamp type through the APIs.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, posix/src/clockgettime.c,
posix/src/pthread.c, posix/src/timersettime.c,
rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgetuptime.c,
rtems/src/ratemonreportstatistics.c, rtems/src/taskwakewhen.c,
rtems/src/timerfirewhen.c, rtems/src/timerserver.c,
rtems/src/timerserverfirewhen.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/thread.h,
score/include/rtems/score/tod.h, score/src/coretod.c,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c,
score/src/threaddispatch.c, score/src/threadinitialize.c: Add
SuperCore handler Timestamp to provide an opaque class for the
representation and manipulation of uptime, time of day, and the
difference between two timestamps. By using SuperCore Timestamp, it
is clear which methods and APIs really have to be struct timespec and
which can be in an optimized native format.
* score/include/rtems/score/timestamp.h,
score/src/coretodgetuptimetimespec.c: New files.
PR 1346/cpukit
* rtems/include/rtems/rtems/ratemon.h: Sense of rate monotonic
statistics nanoseconds or ticks granularity conditional is backwards.
