path: root/cpukit/include/rtems/rtems/optionsimpl.h (follow)
* Do not use RTEMS_INLINE_ROUTINESebastian Huber2022-09-191-2/+2
| | | | | | | Directly use "static inline" which is available in C99 and later. This brings the RTEMS implementation closer to standard C. Close #3935.
* cpukit/include/rtems/rtems/*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* rtems: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* rtems: Canonicalize implementation Doxygen groupsSebastian Huber2020-12-021-2/+4
| | | | | | | | | Rename Classic API top-level group from Classic to RTEMSImplClassic. Use RTEMSImplClassic as a prefix for the subgroups. Change the group names to be in line with the API group names. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: Rename Internal to ImplementationSebastian Huber2020-11-231-1/+1
| | | | | | Use a top-level implementation group to gather implementation related files. The use of "Impl" is shorter and matches with the *impl.h file names.
* doxygen: Restructured cpukit/include/rtems/rtemsAndreas Dachsberger2019-04-021-1/+1
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+67
