path: root/cpukit/include/rtems/rtems/mainpage.h (follow)
* rtems: Generate <rtems/rtems/tasks.h>Sebastian Huber2021-04-281-1/+1
| | | | | | | | Change license to BSD-2-Clause according to file histories and documentation re-licensing agreement. Update #3899. Update #3993.
* doxygen: Added Mainpage to RTEMSAPIClassicAndreas Dachsberger2019-04-041-1/+1
| | | | Update #3706.
* doxygen: Restructured cpukit/include/rtems/rtemsAndreas Dachsberger2019-04-021-1/+1
| | | | Update #3706.
* doxygen: Reviewed cpukit/include/rtems/rtemsAndreas Dachsberger2019-04-021-0/+2
| | | | Update #3706.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Spelling and grammar fixes in source code comments (GCI 2018)Marçal Comajoan Cara2018-12-041-2/+2
* Remove make preinstallChris Johns2018-01-251-0/+927
