Directly include <rtems/score/cpuopts.h> in header files using CPU build
options.
Restrict the affinity set to the set of online processors. Make sure
the affinity set for an interrupt vector contains at least one online
processor.
Update #3269.
Move the data structure definitions closer to the directives which use
them.
Since the previous Interrupt Manager Extension API moved to the
Interrupt Manager, we can move the interfaces to <rtems/rtems/intr.h> so
that they are available via #include <rtems.h>.
Add rtems_interrupt_raise_on(). Document the currently not implemented
rtems_interrupt_clear(). Remove the not implemented and badly named
rtems_interrupt_cause() directive.
Update #3269.
Mention the type of the pointer in the parameter description. Use the
more general term "object" instead of "variable".
Update #3993.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Ensure that interrupts are disabled while acquiring an ISR lock.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
