Updates #3053.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
Rename Classic API top-level group from Classic to RTEMSImplClassic.
Use RTEMSImplClassic as a prefix for the subgroups. Change the group
names to be in line with the API group names. Use common phrases for
the group brief descriptions.
Update #3706.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Update #3598.
Update #3598.
