brains GmbH.
The application configuration options are documented in
"cpukit/doxygen/appl-config.h". Since the application configuration
option defines are also present in multiple test program sources, the
"#OPTION" references cannot be mapped to a unique definition. Add an
anchor for each option and reference it to avoid the issues with the
multiple definitions.
Update #3994.
Update #4572.
Resolution is the right term for the documented property.
Update #4527.
Update #4338.
Mention the type of the pointer in the parameter description. Use the
more general term "object" instead of "variable".
Update #3993.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Separate the definitions related to watchdog ticks from the watchdog
structures.
Update #3598.
Use a real function for rtems_clock_get_uptime_seconds().
Update #3598.
Update #3598.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Add macro implementation for rtems_clock_get_ticks_per_second() for
C/C++ to avoid the function call overhead. A
rtems_clock_get_ticks_per_second() is still provided for language
bindings (e.g. Ada).
This service was marked as deprecated long prior to the 4.11 release
series and is now being removed.
closes #2676.
closes #2357.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
Add rtems_clock_tick_later(), rtems_clock_tick_later_usec() and
rtems_clock_tick_before().
Update documentation.
Add Timestamp support in the score to return a timestamp in nanoseconds.
Add a test.
Update the RTEMS API documentation.
Move the nanoseconds since last tick support from the Watchdog to the
TOD handler. Now the TOD managment is encapsulated in the TOD_Control
structure.
TOD_MILLISECONDS_TO_TICKS().
http://www.google-melange.com/gci/task/view/google/gci2012/7948217
http://www.google-melange.com/gci/task/view/google/gci2012/8015207
http://www.google-melange.com/gci/task/view/google/gci2012/7950206
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025204
* rtems/include/rtems/rtems/clock.h, rtems/src/clockset.c: Added const
qualifier in rtems_clock_set().
* rtems/include/rtems/rtems/clock.h: Eliminate unused type
rtems_clock_time_value.
* libcsupport/include/rtems/libio_.h,
libcsupport/src/fs_null_handlers.c: Null handlers are now const.
* libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create
semaphores on the fly.
* cpukit/libblock/src/bdpart.c: Fixed format specifier.
* cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h,
rtems/inline/rtems/rtems/support.inl: Documentation.
* include/rtems/irq-extension.h: Documentation. Added API for
interrupt servers.
* rtems/include/rtems/rtems/clock.h, rtems/src/clocktodtoseconds.c,
rtems/src/clocktodvalidate.c: Add const to parameter.
