Place the paragraphs in the same order as the directive documentation in
the RTEMS Classic API Guide.
Update #3993.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
The RTEMS_BARRIER_AUTOMATIC_RELEASE and RTEMS_BINARY_SEMAPHORE options
had the same value. In order to better detect a misuse of option values
(for example using RTEMS_BINARY_SEMAPHORE for rtems_barrier_create()),
the options should have unique values.
Close #4054.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
