path: root/cpukit/include/rtems/recorddata.h (follow)
* record: Add system eventsSebastian Huber2019-09-021-4/+4
| | | | Update #3665.
* record: Add system eventsSebastian Huber2019-08-301-31/+31
| | | | | | Add system events for memory allocation/free. Update #3665.
* record: Add system eventsSebastian Huber2019-08-301-10/+10
| | | | | | | Add system events to identify the target system. Add system events to transfer blocks of memory and register sets. Update #3665.
* record: Add more system eventsSebastian Huber2019-08-291-65/+65
| | | | | | | | | | Reduce the system dependencies to allow tracing of very low level functions, for example the interrupt disable/enable. Introduce general purpose RTEMS_RECORD_CALLER and RTEMS_RECORD_LINE events. Update #3665.
* record: Add support for thread namesSebastian Huber2019-07-301-2/+2
* doxygen: New API subgroup TracingAndreas Dachsberger2019-04-041-1/+1
| | | | Update #3706.
* doxygen: Added Version to API->ClassicAndreas Dachsberger2019-04-041-0/+2
| | | | Update #3706.
* record: Add more system eventsSebastian Huber2019-03-121-58/+58
| | | | Update #3665.
* record: Add system call entry/exit eventsSebastian Huber2019-03-121-83/+83
| | | | | | This corresponds to the Linux syscall_entry_* and syscall_exit_* events. Update #3665.
* record: Rename internal per-CPU eventsSebastian Huber2019-03-121-5/+5
| | | | Update #3665.
* record: Add enum value for each eventSebastian Huber2019-01-301-3/+888
| | | | Update #3665.
* Add low level event recording supportSebastian Huber2019-01-291-0/+317
Add low level event recording infrastructure for system and user defined events. The infrastructure is able to record high frequency events such as * SMP lock acquire/release, * interrupt entry/exit, * thread switches, * UMA zone allocate/free, and * Ethernet packet input/output, etc. It allows post-mortem analysis in fatal error handlers, e.g. the last events are in the record buffer, the newest event overwrites the oldest event. It is possible to detect record buffer overflows for consumers that expect a continuous stream of events, e.g. to display the system state in real-time. The implementation supports high-end SMP machines (more than 1GHz processor frequency, more than four processors). Add a new API instead. The implementation uses per-processor data structures and no atomic read-modify-write operations. It is uses per-processor ring buffers to record the events. The CPU counter is used to get the time of events. It is combined with periodic uptime events to synchronize it with CLOCK_REALTIME. The existing capture engine tries to solve this problem also, but its performance is not good enough for high-end production systems. The main issues are the variable-size buffers and the use of SMP locks for synchronization. To fix this, the API would change significantly. Update #3665.
