path: root/cpukit/include/rtems/rbtree.h (follow)
* cpukit/include/rtems: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* sapi: Canonicalize @defgroup and @file commentsSebastian Huber2020-12-021-8/+6
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706.
* doxygen: Restructured cpukit/include/rtems/rtemsAndreas Dachsberger2019-04-021-1/+1
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+456
