Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This helps to detect
* double insert, append, prepend errors, and
* get from empty chain errors.
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
http://www.google-melange.com/gci/task/view/google/gci2012/8006220
In the Red-Black Tree Heap the administration data structures are not
contained in the managed memory area. This can be used for example in a
task stack allocator which protects the task stacks from access by other
tasks.
