path: root/cpukit/include/rtems/qreslib.h (follow)
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+269
