path: root/cpukit/include/rtems/pty.h (follow)
* Update email address of Fernando Ruiz Casas to <fruizcasas@gmail.com>Joel Sherrill2022-04-051-4/+7
| | | | This was requested to be executed prior to relicensing to BSD-2.
* telnetd: Create sessions at startSebastian Huber2018-10-111-1/+10
| | | | Update #3543.
* telnetd: Convert pty driver to new Termios APISebastian Huber2018-10-011-52/+19
| | | | Update #3526.
* Remove make preinstallChris Johns2018-01-251-0/+76
