path: root/cpukit/include/rtems/print.h (unfollow)
2019-04-04doxygen: Print Support now in API->IOAndreas Dachsberger1-1/+1
Update #3706.
2019-04-04doxygen: Put Print Support in IOAndreas Dachsberger1-0/+2
Update #3706.
2019-02-28Remove explicit file names from @fileSebastian Huber1-1/+1
This makes the @file documentation independent of the actual file name. Update #3707.
2016-06-22Move printer initialization to separate headerSebastian Huber1-78/+5
The RTEMS print user need to know nothing about a particular printer implementation. In particular get rid of the <stdio.h> include which would be visible via <rtems.h>.
2016-06-22Make rtems/print.h independent of rtems/bspIo.hSebastian Huber1-5/+16
2016-06-22Rename and move RTEMS_PRINTF_ATTRIBUTE()Sebastian Huber1-1/+1
Rename RTEMS_PRINTF_ATTRIBUTE() into RTEMS_PRINTFLIKE() (similar to <sys/cdefs.h> __printflike()) and move it to <rtems/score/basedefs.h>.
2016-06-06mghttpd: Add RTEMS printer supportSebastian Huber1-2/+2
2016-05-25cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns1-0/+134
This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
