This patch set replaces the CPU budget algorithm enumeration with a set of CPU
budget operations which implement a particular CPU budget algorithm. This
helps to hide the CPU budget algorithm implementation details from the general
thread handling. The CPU budget callouts are turned into CPU budget
operations. This slightly reduces the size of the thread control block.
All schedulers used the default scheduler tick implementation. The tick
scheduler operation is removed and the CPU budget operations are directly used
in _Watchdog_Tick() if the executing thread uses a CPU budget algorithm. This
is performance improvement for all threads which do not use a CPU budget
algorithm (default behaviour).
Clarify group description.
Update #3706.
The priority queues in clustered scheduling configurations use a per
scheduler priority queue rotation to ensure FIFO fairness across
schedulers. This mechanism is implemented in the thread queue surrender
operation. Unfortunately some semaphore and message queue directives
used wrongly the thread queue extract operation. Fix this through the
use of _Thread_queue_Surrender().
Update #4358.
Use the new Priority_Group_order enum instead of a boolean to indicated if a
priority should be inserted as the first or last node into its priority group.
This makes the code more expressive. It is also a bit more efficient since a
branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or
operation can be used.
the timer_create() method can use CLOCK_MONOTONIC
but there was no test for this.
Also it implements the functionality to
create a CLOCK_MONOTONIC timer and gettime() .
Closes #3888
Move the CPU time budget to the thread configuration. This simplifies
_Thread_Initialize().
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Use a top-level implementation group to gather implementation related
files. The use of "Impl" is shorter and matches with the *impl.h file
names.
Hide implementation details.
Update #3959.
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options. These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the
use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and
CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options.
Update #3874.
This file contained duplicate prototypes for standard POSIX functions
declared in <time.h>.
Rename to use proper namespace.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Update #3598.
Update #2514.
Update #2514.
Use separate configuration variables to avoid false dependencies.
Update #2514.
Enable support for string objects names unconditionally. Add const
qualifier throughout. Split _Objects_Namespace_remove() into
_Objects_Namespace_remove_u32() and _Objects_Namespace_remove_string()
to avoid an unnecessary dependency on _Workspace_Free().
Update #2514.
Update #2514.
Make CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE configurable by the user.
Update #3434.
Update #3342.
Update #3343.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
