path: root/cpukit/include/rtems/posix/shm.h (unfollow)
2022-02-28cpukit/include/rtems/posix/*.h: Change license to BSD-2Joel Sherrill1-3/+22
Updates #3053.
2018-12-14score: Static Objects_Information initializationSebastian Huber1-1/+24
Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
2018-11-12score: Move internal structures to objectdata.hSebastian Huber1-1/+1
Update #3598.
2018-10-29posix: Split posix_api_configuration_tableSebastian Huber1-0/+4
Use separate configuration variables to avoid false dependencies. Update #2514.
2018-01-25Remove make preinstallChris Johns1-0/+0
2017-09-22posix shm: Add oflag to Shm_ControlJoel Sherrill1-0/+1
2017-05-05posix/mman: add mmap support for shm objectsGedare Bloom1-0/+30
Update #2859.
2017-01-13posix: shared memory supportGedare Bloom1-0/+182
Add POSIX shared memory manager (Shm). Includes a hook-based approach for the backing memory storage that defaults to the Workspace, and a test is provided using the heap. A test is also provided for the basic use of mmap'ing a shared memory object. This test currently fails at the mmap stage due to no support for mmap.
