path: root/cpukit/include/rtems/posix/posixapi.h (follow)
* posix: Remove "RTEMS" from POSIX API groupSebastian Huber2021-10-061-3/+4
| | | | | | Clarify group description. Update #3706.
* posix: Delete unused _POSIX_Fatal_error()Sebastian Huber2020-12-021-18/+0
* doxygen: Rename Internal to ImplementationSebastian Huber2020-11-231-1/+1
| | | | | | Use a top-level implementation group to gather implementation related files. The use of "Impl" is shorter and matches with the *impl.h file names.
* doxygen: Put C Library Support and POSIX in InternalAndreas Dachsberger2019-04-041-0/+2
| | | | Update #3706.
* posix: Remove unused _POSIX_Get_object_body()Sebastian Huber2019-02-121-41/+0
* Remove make preinstallChris Johns2018-01-251-0/+146
