* | pci.h add PCI_COMMAND_INTX_DISABLE definition. | Pavel Pisa | 2016-10-11 | 1 | -0/+1 |
* | pci.h cleanup - Consolidate common defines to cpukit pci.h | Joel Sherrill | 2012-05-16 | 1 | -4/+8 |
| | | | | | | | | | | | | | + libbsp/sparc/shared/include/pci.h was largely a copy of an older version of the cpukit pci.h. Removed much of the contents and included <rtems/pci.h>. + sparc/*/pci*.c - Move to <rtems/pci.h> required updating to use uint32_t for dword accesses. + Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION + Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove PCI_MULTI_FUNCTION definitions in C files. + Move PCI_INVALID_VENDORDEVICEID definitions from various C files to cpukit pci.h | ||||
* | mvme5500 and cpukit pci.h - Eliminate mvme5500 specific pci.h | Joel Sherrill | 2012-05-16 | 1 | -2/+12 |
| | | | | | | | | All constants that should have been in cpukit pci.h were moved there. One naming style was corrected. This impacted if_wm.c. All other contents were the same as powerpc/shared/pci.h so BSP specific pci.h could be eliminated. | ||||
* | 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-24 | 1 | -2/+6 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen. | ||||
* | 2009-12-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-11 | 1 | -2/+2 |
| | | | | | PR 1483/cpukit * include/rtems/pci.h: Rename pci_config into rtems_pci_config_t. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -3/+3 |
* | Make pci_[read|write]_config* static inline, again. | Ralf Corsepius | 2009-10-01 | 1 | -6/+6 |
* | 2009-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-01 | 1 | -1/+1 |
| | | | | * include/rtems/pci.h: Add another missing prototype. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -1/+1 |
| | | | | * include/rtems/pci.h: Add missing prototype. | ||||
* | 2009-09-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-28 | 1 | -6/+6 |
| | | | | * include/rtems/pci.h: Revert extern inline patch. | ||||
* | 2009-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-25 | 1 | -6/+6 |
| | | | | * include/rtems/pci.h: Change extern inline to static inline. | ||||
* | 2007-07-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-07-26 | 1 | -0/+8 |
| | | | | | | * include/rtems/bspIo.h, include/rtems/pci.h: Add extern "C" guards. Reported by Robert S. Grimes <rsg@alum.mit.edu>. | ||||
* | adapted BSP "motorola_powerpc" to support MVME24xx | Thomas Doerfler | 2007-04-09 | 1 | -0/+1 |
* | 2007-03-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-31 | 1 | -6/+6 |
| | | | | * include/rtems/pci.h: Further stdint.h fixed-size types. | ||||
* | 2007-03-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-30 | 1 | -6/+8 |
| | | | | * include/rtems/pci.h: Use stdint.h fixed size-types. | ||||
* | 2005-05-04 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-04 | 1 | -1/+1 |
| | | | | * include/rtems/pci.h: Name change to support common PCI interface | ||||
* | 2005-03-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-03-14 | 1 | -0/+16 |
| | | | | | * include/rtems/pci.h: Continue PCI API unification. All use pci_find_device(). | ||||
* | 2005-03-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-03-04 | 1 | -1066/+1119 |
| | | | | | * include/rtems/pci.h: Clean up and reformatting. Make PCI initialize function part of the unified PCI API. | ||||
* | 2005-02-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-17 | 1 | -4/+7 |
| | | | | | * include/rtems/pci.h: Merge differences from libbsp/powerpc/shared/pci/pci.h. | ||||
* | New header guards. | Ralf Corsepius | 2005-01-28 | 1 | -3/+3 |
* | 2004-11-10 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2004-11-10 | 1 | -7/+7 |
| | | | | | | | * include/rtems/pci.h: BSPs use the name BSP_pci_configuration not pci. Also need to address that this largely duplicates libbsp/powerpc/pci/pci.h but that file is not used when both are included due to the same double inclusion protection. | ||||
* | 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-23 | 1 | -0/+1153 |
PR/589 rtems * include/rtems/pci.h: New (Moved from c/src/libchip/network/pci.h). |
