path: root/cpukit/include/rtems/nvdisk-sram.h (unfollow)
2019-02-28Remove explicit file names from @fileSebastian Huber1-1/+1
This makes the @file documentation independent of the actual file name. Update #3707.
2018-01-25Remove make preinstallChris Johns1-0/+0
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-06-242011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-6/+6
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen.
2009-11-29Whitespace removal.Ralf Corsepius1-1/+1
2008-05-012008-05-01 Chris Johns <chrisj@rtems.org>Chris Johns1-0/+25
* libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libblock/src/nvdisk-sram.c, libblock/src/nvdisk.c: New. A Non-volatile memory disk drive. * Makefile.am, preinstall.am, libblock/Makefile.am: Updated for the NV disk driver.
