This makes the @file documentation independent of the actual file name.
Update #3707.
Update #2514.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Display the scheduler name instead of the current CPU in the "task"
shell command. The current CPU could be misleading in case locking
protocols are involved. The "cpuuse" command can be used to obtain the
current CPU.
Print wait object identifier only if it exists.
Update #2858.
Add the special thread queue name _Thread_queue_Object_name to mark
thread queues embedded in an object with identifier. Using the special
thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for
this purpose since the thread wait information and thread state are
protected by different SMP locks in separate critical sections. Remove
STATES_THREAD_QUEUE_WITH_IDENTIFIER.
Add and use _Thread_queue_Object_initialize().
Update #2858.
Update #2858.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
This avoids the "0x0xabc" output and is more compact.
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
application visible API.
* libfs/src/dosfs/fat_file.c, libmisc/monitor/monitor.h,
score/cpu/m68k/rtems/score/cpu.h: Remove stray spaces from unsigned32
to uint32_t conversion.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h: Add const
to fix warning. Spacing.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h: Add reset
command.
* libblock/src/ide_part_table.c: Fixed NULL pointer access.
* libmisc/monitor/mon-command.c, libmisc/monitor/mon-editor.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h,
libmisc/shell/cmds.c: The list of registered monitor commands is now
private and only accessible via a lookup and iterate function.
* libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h:
Fixed incompatible return value.
* libmisc/cpuuse/cpuusagereport.c: Changed output format.
* libmisc/Makefile.am, libmisc/monitor/mon-editor.c: New file.
* libmisc/capture/capture-cli.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/shell/cat_file.c,
libmisc/shell/cmds.c, libmisc/shell/internal.h,
libmisc/shell/main_help.c, libmisc/shell/shell.c,
libmisc/shell/shell.h, libmisc/shell/shell_cmdset.c,
libmisc/shell/shell_getchar.c, libmisc/shell/str2int.c: Various global
data is now read only. Added 'const' qualifier to many pointer
parameters. It is no longer possible to remove monitor commands.
Moved monitor line editor into a separate file to avoid unnecessary
dependencies.
* libcsupport/include/rtems/libio_.h, libcsupport/src/libio_sockets.c,
libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/imfs/deviceio.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/stackchk/internal.h,
rtems/inline/rtems/rtems/part.inl, score/include/rtems/system.h,
score/include/rtems/score/bitfield.h, score/src/mpci.c,
score/src/objectextendinformation.c, score/src/threadmp.c: Remove
extraneous spaces.
* libmisc/monitor/monitor.h, rtems/include/rtems/rtems/tasks.h,
score/include/rtems/score/thread.h, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadstart.c: New type
Thread_Entry_numeric_type for numeric arguments in thread entry
functions with at least one numeric argument.
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c:
Changed option set type to rtems_option.
* score/src/objectgetinfo.c: Check return value of
_Objects_API_maximum_class().
* libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h,
rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c,
rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h,
score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgseize.c,
score/src/coremsgsubmit.c:
Removed parameters of _Message_queue_Allocate(). Changed option set
type to rtems_option. Changed type of maximum message and packet size
to size_t. Changed the input buffer type for message send functions to
"const void *". Changed the pointer to the second return argument in
the thread wait information to a union. This union can contain a
pointer to an immutable or a mutable object. This is somewhat fragile.
An alternative would be to add a third pointer for immutable objects,
but this would increase the structure size.
* libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-part.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-region.c,
libmisc/monitor/mon-sema.c, libmisc/monitor/mon-task.c,
libmisc/monitor/monitor.h: Use rtems_object_get_name() instead of
internal routine. This makes it possible to also print string names
of POSIX objects. Adjust task report to realign since we can have
longer names.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c,
libmisc/monitor/monitor.h, libmisc/shell/main_chmod.c,
libmisc/shell/main_tty.c, libmisc/shell/main_umask.c,
libmisc/shell/main_whoami.c: Add pthread command to monitor when
POSIX is enabled. Remove include of rtems/monitor.h from files not
related.
* libmisc/monitor/monitor.h: Add network commands that were in the
network supplement but not in the code.
* libmisc/monitor/mon-network.c: New file.
libmisc/monitor/monitor.h: Merge minor parts of Thomas' improvements
that are needed by osmonweb.
* libmisc/Makefile.am, libmisc/monitor/mon-object.c,
libmisc/monitor/monitor.h, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/io.c: Eliminate maximum_drivers
configuration parameter since it was used to configure a no longer
used feature. Device names are now part of the filesystem not in a
table. This also eliminated the variables _IO_Number_of_devices and
_IO_Driver_name_table from RTEMS as well as the memory allocation
used to populate _IO_Driver_name_table.
* libmisc/monitor/mon-dname.c: Removed.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/monitor/monitor.h, libmisc/rtmonuse/rtmonuse.h,
libmisc/shell/shell.h: Partial doxygenification.
* libmisc/capture/capture.h: Use INT32_C for constants.
* monitor/monitor.h: Let rtems_monitor_config_dump return int.
* monitor/mon-config.c: Ditto. Use PRI*N macros.
* monitor/mon-itask.c, monitor/mon-prmisc.c: Use PRI*N macros.
* monitor/mon-prmisc.c, monitor/monitor.h: Let rtems_monitor_dump
return int's not uint32_t (They are printf return values).
* libmisc/monitor/mon-prmisc.c, libmisc/monitor/monitor.h:
rtems_monitor_dump_char(char ch).
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c,
libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c,
libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/monitor/symbols.h,
libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c,
libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h,
libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c,
libmisc/stackchk/internal.h: Convert to using c99 fixed size types.
PR 495/rtems_misc
* capture/capture-cli.c, monitor/mon-command.c, monitor/mon-config.c,
monitor/mon-monitor.c, monitor/mon-object.c, monitor/mon-symbols.c,
monitor/monitor.h, shell/cmds.c: Move to making libmisc 16/32 bit
clean.
Add rtems_monitor_commands[] (Illegally applied by shell/).
Remove ifdef(__mips64) (Make broken code visible again).
* monitor/mon-command.c: Add several ifndef RTEMS_UNIX to avoid
warnings.
* monitor/mon-monitor.c: Remove RTEMS_CPU_HAS_16_BIT_ADDRESSES (Make
* shell/cmds.c: Remove local decls of rtems_monitor_commands[].
* monitor/monitor.h: Remove STREQ, STNEQ (pollute namespace),
RTEMS_MONITOR_PROMPT (pollutes namespace, useless).
* monitor/mon-command.c: Add RTEMS_MONITOR_PROMPT.
* monitor/mon-monitor.c: Apply private version of STREQ.
* monitor/symbols.h: Convert to private header.
* monitor/monitor.h: Don't include symbols.h.
Add forward decls. for symbols from symbols.h.
* monitor/Makefile.am: Don't install symbols.h.
* monitor/mon-symbols.c: Include "symbols.h".
* capture/capture-cli.c, cpuuse/cpuuse.c, monitor/mon-monitor.c,
monitor/mon-object.c, monitor/monitor.h: Corrected use of
_Objects_Information_table now that it is a two dimensional
array based upon API and class. In addition, in the monitor,
corrected an error which occured when a target has 64 bit pointers.
to:
I have also added the ability to register and unregister commands. This
allows me to create a set of monitor commands for the network stack plus
basic memory dump/patch commands (needs a working probe interface). I
will also look at a basic ls/cd/rm/mv/cp command set at some stage.
I have been thinking about changing the monitor in the future to more
like a light weight RTEMS shell, `eshell' for embedded shell. This is a
story for another day but is a process or getting the commands to map to
the filesystem (eg, major=commands, minor=command) and supporting an
environment. The filesystem provide a structure for the commands.
it work.
