path: root/cpukit/include/rtems/libio_.h (follow)
* 2001-01-25 Fernando Ruiz <fernando.ruiz@ctv.es>Joel Sherrill2001-01-251-9/+20
| | | | | | | | | | * Alternate email is correo@fernando-ruiz.com * libc/privateenv.c: New file. * include/rtems/libio_.h, libc/Makefile.am, libc/base_fs.c, libc/unmount.c: Moved default umask, current working directory, root, and links followed count into a structure "user environment" that can then be treated as a unit. This enable giving unique copies of these to individual threads or collection of threads.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-2/+2
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-2/+2
| | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
* Split null handlers table to own file and renamed.Joel Sherrill1999-10-121-1/+2
| | | | Renamed IMFS handler tables to include IMFS prefix.
* Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1999-10-121-0/+12
| | | | | places to make sure memory allocated for filesystem specifif nodes gets freed.
* Use proper include for libio.h.Joel Sherrill1999-03-161-4/+1
* Added F_GETFL support so the fdopen() implementation in newlib 1.8.1Joel Sherrill1999-03-061-0/+4
| | | | | | | | would work. At the same time, the initial implementation of F_SETFL was added. A support routine was added to convert internal libio flags back to the POSIX style. Eventually the internal representation should be eliminated in the interest of simplicity and code reduction. This problem was reported by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
* Patch from Eric Norum <eric@skatter.usask.ca> to eliminate externalJoel Sherrill1999-03-011-9/+0
| | | | | IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine.
* More general fix based on bug report and patch from Ian Lance TaylorJoel Sherrill1999-01-201-1/+15
| | | | | | | | | | <ian@airs.com> to fix this problem: There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It does not check whether the file descriptor it is passed is open. This can cause it to make a null dereference if it is passed a file descriptor which is in the valid range but which was not opened, or which was already closed.
* Merged Eric Norum's select patch that was based on 4.0 and resolvedJoel Sherrill1998-12-101-0/+1
| | | | all conflicts.
* Modifications for RTEMS_UNIX.Jennifer Averett1998-12-031-0/+5
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+248
