path: root/cpukit/include/rtems/libio.h (follow)
* Change filesystem utime_h handler to utimens_hRyan Long2021-05-281-20/+35
| | | | | | | Also updated licenses. Closes #4400 Updates #3899
* libcsupport: Add no_regular_file_mknod as a mount option to the mount tableChris Johns2021-02-081-0/+1
| | | | | | | | | | | | | - Add the bool flag no_regular_file_mknod to the mount table so a file system can indicate creating regular files is not done by use the mknod handler. The file system will handle creating a file node in the open handler. - Note, the mount option is an enum which means there is only one exclusive option supported. As a result no encapsulation is provided and file systems need to set no_regular_file_mknod directly. Closes #4222
* libio: Move to RTEMS implementation groupSebastian Huber2020-11-231-0/+2
* termios: Replace rtems_termios_isig_status_codeSebastian Huber2020-05-071-19/+28
| | | | | | | | | | Merge the rtems_termios_isig_status_code and rtems_termios_iproc_status_code enums into a single rtems_termios_iproc_status_code which is now a part of the API. Simplify rtems_termios_posix_isig_handler() to avoid unreachable code. Close #3800.
* libio: Remove RTEMS_FILESYSTEM_TYPE_MINIIMFSSebastian Huber2020-04-021-3/+0
| | | | | This type is unused. Do not mention non-existing CONFIGURE_FILESYSTEM_MINIIMFS.
* config: Remove CONFIGURE_FILESYSTEM_DEVFSSebastian Huber2020-03-311-3/+0
| | | | | | | | This filesystem no longer exists. Remove unused RTEMS_FILESYSTEM_TYPE_DEVFS. Update #3894.
* libio: Robust file descriptor reference countingSebastian Huber2020-03-131-1/+1
| | | | | | | | | | | | There was a race conditon in the reference counting of file descriptors during a close() operation. After the call to the close handler, the rtems_libio_free() function cleared the flags to zero. However, at this point in time there may still exist some holders of the file descriptor. With RTEMS_DEBUG enabled this could lead to failed assertions in rtems_libio_iop_drop(). Change the code to use only atomic read-modify-write operations on the rtems_libio_iop::flags.
* termios: Add Capability to Generate SIGINTR and SIGQUITJoel Sherrill2019-10-081-6/+110
| | | | | | | | | | | | | | This patch adds the ability for termios to send SIGINTR on receipt of VINTR and SIGQUIT for VKILL and return -1/EINTR from read() on a termios channel. Importantly, this patch does not alter the default behavior or force POSIX signal code in just because termios is used. The application must explicitly enable the POSIX behavior of generating a signal upon receipt of these characters. This is discussed in the POSIX standard: https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap11.html Closes #3800.
* termios: Use self-contained objectsSebastian Huber2018-02-021-1/+4
| | | | Update #2840.
* Remove make preinstallChris Johns2018-01-251-0/+1967
