path: root/cpukit/include/rtems/io.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-0/+0
2016-03-14score: Use ISR lock for IO driver registrationSebastian Huber1-13/+0
Create implementation header file. Update #2555.
2016-03-14score: Delete unused SAPI_IO_EXTERNSebastian Huber1-4/+0
Update #2559.
2015-10-26basdefs.h: Add and use RTEMS_DEPRECATEDSebastian Huber1-1/+1
2015-04-17sapi: Avoid declaration in source, fix typeSebastian Huber1-0/+2
2014-04-10score: Statically initialize IO managerSebastian Huber1-11/+2
This simplifies the RTEMS initialization and helps to avoid a memory overhead. The workspace demands of the IO manager were not included in the <rtems/confdefs.h> workspace size estimate. This is also fixed as a side-effect. Update documentation and move "Specifying Application Defined Device Driver Table" to the section end. This sub-section is not that important for the user. Mentioning this at the beginning may lead to confusion.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-01-10cpukit: Use Consistent Beginning of Doxygen Group NotationJoel Sherrill1-3/+2
This is the result of a sed script which converts all uses of @{ into a consistent form.
2013-01-08sapi: Doxygen Clean Up Task #1Alex Ivanov1-47/+47
2012-12-28Header File Doxygen Enhancement Task #1Alex Ivanov1-3/+1
2012-12-18libfs: Doxygen Enhancement Task #2Alex Ivanov1-1/+6
http://www.google-melange.com/gci/task/view/google/gci2012/8032207
2012-12-09sapi: Fix previous commitSebastian Huber1-23/+1
2012-12-07sapi misc: Clean up Doxygen GCI task #1Christopher Kerl1-8/+104
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-10-102011-10-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+1
* libfs/src/devfs/devfs_mknod.c: Remove const cast. * libfs/src/imfs/ioman.c: Remove const cast. * libfs/src/devfs/devfs.h: Make device_name a const char*. * sapi/include/rtems/io.h: Make device_name a const char*.
2009-11-29Whitespace removal.Ralf Corsepius1-1/+1
2009-10-092009-10-09 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill1-0/+2
* cpukit/sapi/include/rtems/io.h: Documentation. * cpukit/sapi/src/ioregisterdriver.c: Call from interrupt context is an error. * cpukit/sapi/src/iounregisterdriver.c: Disable preemption during critical section.
2009-10-052009-10-04 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill1-161/+91
* sapi/include/rtems/io.h, sapi/src/ioregisterdriver.c: Documenation. rtems_io_lookup_name() is now deprecated. Added rtems_io_driver_io_error(). rtems_io_register_driver() is now thread-safe.
2009-02-05Move extern "C" brace after includes.Ralf Corsepius1-2/+2
2008-12-172008-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-6/+2
* sapi/include/rtems/extension.h, sapi/include/rtems/io.h, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c, score/include/rtems/score/mpci.h, score/include/rtems/score/object.h, score/include/rtems/score/thread.h, score/include/rtems/score/tod.h, score/include/rtems/score/userext.h, score/include/rtems/score/wkspace.h, score/src/coretod.c, score/src/mpci.c, score/src/object.c, score/src/thread.c, score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and SuperCore Handler initialization routines to directly pull parameters from configuration table.
2008-05-27Added const qualifier to various pointers and data tables toThomas Doerfler1-1/+1
reduce size of data area. IMFS: Fixed creation of symbolic links to avoid a compiler warning. DOSFS: Use LibBlock instead of read() to read the boot record.
2007-05-292007-05-29 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-2/+6
* sapi/Makefile.am, sapi/include/rtems/io.h, sapi/src/io.c: Split into one function per file execpt io.c which contains required initialization methods. * sapi/src/ioclose.c, sapi/src/iocontrol.c, sapi/src/iodata.c, sapi/src/ioinitialize.c, sapi/src/ioopen.c, sapi/src/ioread.c, sapi/src/ioregisterdriver.c, sapi/src/iounregisterdriver.c, sapi/src/iowrite.c: New files.
2007-05-282007-05-28 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-4/+1
* libmisc/Makefile.am, libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/io.h, sapi/src/exinit.c, sapi/src/io.c: Eliminate maximum_drivers configuration parameter since it was used to configure a no longer used feature. Device names are now part of the filesystem not in a table. This also eliminated the variables _IO_Number_of_devices and _IO_Driver_name_table from RTEMS as well as the memory allocation used to populate _IO_Driver_name_table. * libmisc/monitor/mon-dname.c: Removed.
2006-01-082006-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* sapi/include/rtems/io.h, sapi/src/io.c: Change rtems_io_register_name to take a const char *.
2005-01-28New header guard.Ralf Corsepius1-2/+2
2005-01-182005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+1
* sapi/include/rtems/io.h : size_t device_name_length.
2004-11-21Add doxygen preamble.Ralf Corsepius1-2/+5
2004-04-16Remove stray white spaces.Ralf Corsepius1-4/+4
2004-03-292004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-8/+8
* sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h, sapi/include/rtems/init.h, sapi/include/rtems/io.h, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/fatal.c, sapi/src/io.c: Convert to using c99 fixed size types.
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* include/confdefs.h, include/rtems/config.h, include/rtems/extension.h, include/rtems/fatal.h, include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h, include/rtems/sptables.h, include/rtems/sptables.h.in, inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c, src/exinit.c, src/extension.c, src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c, src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license changed.
2003-02-032003-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
PR 338/filesystem * include/rtems/io.h, src/io.c: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change).
2001-10-162001-10-16 Chris Johns <ccj@acm.org>Joel Sherrill1-0/+29
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h, optman/no-io.c, src/exinit.c, src/io.c: Added a device driver register/unregister interface to allow device drivers to be installed and removed at runtime. This means you do not need devices present in the device table when you build.
2000-09-282000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-6/+6
* include/rtems/io.h (rtems_driver_address_table): Added "_entry" to all names. * src/io.c: Accounted for above.
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1996-05-28split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1-4/+4
1996-02-21changed io manager initialization routine to not be staticJoel Sherrill1-3/+1
1995-10-31typos fixedJoel Sherrill1-11/+11
1995-09-11The word "RTEMS" almost completely removed from the core.Joel Sherrill1-12/+44
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
1995-08-17Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1-44/+54
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
1995-05-24Fully tested on all in-house targetsJoel Sherrill1-3/+3
