path: root/cpukit/include/rtems/init.h (follow)
* rtems: Generate <rtems/init.h>Sebastian Huber2021-04-211-29/+103
| | | | | | | | Change license to BSD-2-Clause according to file histories and documentation re-licensing agreement. Update #3899. Update #3993.
* rtems: Improve RTEMS_NO_RETURN attributeSebastian Huber2020-10-101-5/+2
| | | | | | | | | | | Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors like this: error: no return statement in function returning non-void [-Werror=return-type] Use C11 and C++11 standard means to declare a no-return function. Close #4122.
* rtems: Move includes out of extern "C" scopeSebastian Huber2018-11-081-4/+4
* Remove make preinstallChris Johns2018-01-251-0/+69
