path: root/cpukit/include/rtems/extension.h (follow)
* rtems: Generate <rtems/extension.h>Sebastian Huber2021-09-151-177/+588
| | | | | | | | | | | | Remove the duplicated description which is an out dated copy and paste from the Classic API Guide. Instead, thoroughly document the individual extensions. Change license to BSD-2-Clause according to file histories and documentation re-licensing agreement. Update #3899. Update #3993.
* sapi: Canonicalize @defgroup and @file commentsSebastian Huber2020-12-021-5/+5
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706.
* rtems: Remove deprecated rtems_extensionSebastian Huber2020-07-141-3/+0
| | | | | | This type was deprecated in RTEMS 5.1. Close #3988.
* doxygen: Restructured cpukit/include/rtems/rtemsAndreas Dachsberger2019-04-021-1/+1
| | | | Update #3706.
* rtems: Move internal structures to extensiondata.hSebastian Huber2018-11-121-8/+4
| | | | Update #3598.
* rtems: Move includes out of extern "C" scopeSebastian Huber2018-11-081-4/+4
* Remove make preinstallChris Johns2018-01-251-0/+245
