path: root/cpukit/include/rtems/dosfs.h (follow)
* cpukit/include/rtems: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* dosfs: Fix memory leak on failed mounts.Christian Mauderer2020-08-041-0/+7
| | | | | | | | | | | | | | | | | | | | Currently if mount fails, a converter isn't destroyed. We have to take care of two cases: 1. The user doesn't provide a converter. In this case mounting a dosfs creates a default converter. This patch makes sure that the converter is destroyed again if mount failes for this case. 2. The user provides a converter. In this case it's not sure that the dosfs specific routines are reached because mount can fail before that. Therefore the user has to destroy the converter himself again. This patch adds a documentation for that and implements it in the media server. Closes #4042.
* Remove make preinstallChris Johns2018-01-251-0/+433
