path: root/cpukit/include/rtems/devnull.h (follow)
* doxygen: Zero and Null Device Drivers now in Device DriversAndreas Dachsberger2019-04-041-1/+1
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+84
