Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
Use the right system initialization step for the stack allocator
initialization. Do the stack allocator initialization before the
workspace initialization so that _Memory_Allocate() can be used to get
memory for the allocator.
Expressions in static assertions must be integral constant expressions. In
integral constant expressions the use of address constant expressions is not
allowed.
In static initializers the address constant expressions are allowed. Introduce
a new macro _CONFIGURE_ASSERT_NOT_NULL() which leads to a compile time error if
the second parameter is NULL. It generates error messages like this if for
example
#define CONFIGURE_INIT_TASK_ENTRY_POINT NULL
is provided by the application:
cpukit/include/rtems/confdefs/inittask.h:51:26: error: size of unnamed array is negative
51 | ( _type ) sizeof( int[ ( _value ) != NULL ? 1 : -1 ] ) )
cpukit/include/rtems/confdefs/inittask.h:170:3: note: in expansion of macro '_CONFIGURE_ASSERT_NOT_NULL'
170 | _CONFIGURE_ASSERT_NOT_NULL(
This fix relates to CID 1470570 (PARSE_ERROR).
Update #4181.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
Register a custom task stack allocator initialization handler only if
necessary.
Replace runtime checks with compile time assertions. This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
_Workspace_Area. Introduce _Workspace_Malloc_initializer to have this
dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
application configuration.
Merge CORE_message_queue_Buffer structure into
CORE_message_queue_Buffer_control.
Use a zero-length array for the actual message buffer. This reduces the
structure size on all targets.
Update #4007.
In contrast to rtems_task_create() this function constructs a task with
a user-provided task storage area. The new directive uses a
configuration structure instead of individual parameters.
Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a
task storage area based on the task attributes and the size dedicated to
the task stack and thread-local storage. This macro may allow future
extensions without breaking the API.
Add application configuration option
CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS
Workspace size estimate.
Update #3959.
Do the stack allocator initialization and sanity check only if a
user-provided stack allocator was configured. This avoids a dependency
of _Thread_Handler_initialization() on the stack allocator.
Update #3959.
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Change licence of <rtems/confdefs.h> to BSD-2-Clause according to file
history.
Update #3053.
Close #3875.
