brains GmbH.
By default, allocate the IDLE task storage areas from the RTEMS Workspace.
This avoids having to estimate the thread-local storage size in the default
configuration.
Add the application configuration option CONFIGURE_IDLE_TASK_STORAGE_SIZE to
request a static allocation of the task storage area for IDLE tasks.
Update #3835.
Update #4524.
Evaluate CONFIGURE_DISABLE_BSP_SETTINGS for each affected application
configuration option. This makes the code easier to review since the influence
of CONFIGURE_DISABLE_BSP_SETTINGS is locally visible in the code.
Update #3875.
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
In the previous implementation, the _ISR_Stack_area_begin and
_ISR_Stack_area_end symbols were in different sections. If they do not
have the same alignment, then the following linker directive could
separate them:
*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
Do not use different sections and instead define _ISR_Stack_area_end
directly.
Update #3799.
This reverts commit 8e80876bdd54e36fb668eee655eec1dd588daf13
which broke several architectures.
The _ISR_Stack_area_begin and _ISR_Stack_area_end symbols are in
different sections. They must have the same alignment, otherwise the
following linker directive could separate them:
Update #3799.
Remove comments and copyrightable content from the moved content. Use
BSD-2-Clause for new file according to file history of
<rtems/confdefs.h>.
Update #3053.
Update #3875.
