* | config: Canonicalize @defgroup and @file comments | Sebastian Huber | 2020-12-02 | 1 | -2/+3 |
| | | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706. | ||||
* | config: Fix typo | Sebastian Huber | 2020-04-14 | 1 | -1/+1 |
| | | | | Update #3875. | ||||
* | imfs: Replace devfs with an IMFS specialization | Sebastian Huber | 2020-03-09 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | Add a simplified path evaluation function IMFS_eval_path_devfs() for a device only IMFS configuration. The code size can be further reduced by the application if it disables the support for legacy IO drivers via: #define CONFIGURE_IMFS_DISABLE_MKNOD #define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES. Update #3894. Update #3898. | ||||
* | config: Add <rtems/confdefs/obsolete.h> | Sebastian Huber | 2020-02-25 | 1 | -0/+234 |
Unify handling of obsolete configuration options. Remove comments and copyrightable content from the moved content. Use BSD-2-Clause license for new file. Update #3053. Update #3875. |
