* | config: Canonicalize @defgroup and @file comments | Sebastian Huber | 2020-12-02 | 1 | -2/+3 |
| | | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706. | ||||
* | config: Add <rtems/confdefs/malloc.h> | Sebastian Huber | 2020-02-25 | 1 | -0/+72 |
Remove all comments and copyrightable content from the moved content. Use BSD-2-Clause license for new file. Move the default configuration to library files so that application configurations do not include the definitions for the default case. Update #3053. Update #3875. |
