Expressions in static assertions must be integral constant expressions. In
integral constant expressions the use of address constant expressions is not
allowed.
In static initializers the address constant expressions are allowed. Introduce
a new macro _CONFIGURE_ASSERT_NOT_NULL() which leads to a compile time error if
the second parameter is NULL. It generates error messages like this if for
example
#define CONFIGURE_INIT_TASK_ENTRY_POINT NULL
is provided by the application:
cpukit/include/rtems/confdefs/inittask.h:51:26: error: size of unnamed array is negative
51 | ( _type ) sizeof( int[ ( _value ) != NULL ? 1 : -1 ] ) )
cpukit/include/rtems/confdefs/inittask.h:170:3: note: in expansion of macro '_CONFIGURE_ASSERT_NOT_NULL'
170 | _CONFIGURE_ASSERT_NOT_NULL(
This fix relates to CID 1470570 (PARSE_ERROR).
Update #4181.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
