Evaluate CONFIGURE_DISABLE_BSP_SETTINGS for each affected application
configuration option. This makes the code easier to review since the influence
of CONFIGURE_DISABLE_BSP_SETTINGS is locally visible in the code.
Update #3875.
This adds a confdef option allowing an application to request mapping
machine exceptions to POSIX signals. This is required for some languages
such as Ada.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
Check for configuration errors earlier. Allow fatal dumps without the
other extensions. Add some warnings.
Update #3904.
Add rtems_record_dump_base64() and rtems_record_dump_base64_zlib().
Add CONFIGURE_RECORD_FATAL_DUMP_BASE64 and
CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB configuration options.
Update #3904.
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
