2019-02-28 | Remove explicit file names from @file | Sebastian Huber | 1 | -1/+1 | |
This makes the @file documentation independent of the actual file name. Update #3707. | |||||
2018-01-25 | Remove make preinstall | Chris Johns | 1 | -0/+0 | |
A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254. | |||||
2016-09-01 | libmisc/capture: Fix the capture engine on SMP. | Chris Johns | 1 | -3/+2 | |
This patches some issues with the capture engine: 1. Check is the engine is open in ctrace commands. 2. Check all record open and appends for overflow. 3. Fix the record open to take the size of user data and not the record header. 4. Use packed structs for data being written to the per cpu buffers. 5. Remove direct struct access to the capture buffers to avoid misaligned accesses. 6. Add support to extract records, no struct access to the capture buffers. 7. Update ctrace to extract records from the capture buffers. 8. Add support to ctrace to always print the task name if it has one. 9. Add support to manage names or the lack of a name. 10. Range of minor fixes. 11. Fix a long standing bug in ctset's handling of args. Closes #2780. | |||||
2015-03-11 | cpukit: Remove old DESCRIPTION: in comments | Joel Sherrill | 1 | -3/+0 | |
These were remnants of pre-Doxygen comment style. | |||||
2014-11-24 | capture: Remove whitespace and fix copyrights. | Jennifer Averett | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-06-24 | 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+3 | |
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen. | |||||
2004-12-02 | 2004-12-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+5 | |
* libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/monitor/monitor.h, libmisc/rtmonuse/rtmonuse.h, libmisc/shell/shell.h: Partial doxygenification. * libmisc/capture/capture.h: Use INT32_C for constants. | |||||
2004-04-16 | Remove stray white spaces. | Ralf Corsepius | 1 | -2/+2 | |
2002-05-15 | 2002-05-16 Chris Johns <ccj@acm.org> | Joel Sherrill | 1 | -0/+52 | |
* Per PR194, added the Capture engine. * capture/Makefile.am, capture/README, capture/capture-cli.c, capture/capture-cli.h, capture/capture.c, capture/capture.h, capture/.cvsignore: New files. * Makefile.am, configure.ac, wrapup/Makefile.am: Modified to reflect addition. |
