path: root/cpukit/include/rtems/bspIo.h (follow)
* doxygen: Print Support now in API->IOAndreas Dachsberger2019-04-041-1/+1
| | | | Update #3706.
* doxygen: Added some subgroups to IO LibraryAndreas Dachsberger2019-04-041-0/+2
| | | | | | Update #3706. Types and Mount, IO Internal, Kernel Print Support
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* tests: Move rtems_test_printer definitionSebastian Huber2017-10-281-0/+6
| | | | | | | Statically initialize it to use printk(). Update #3170. Update #3199.
* Simplify and unify BSP_output_charSebastian Huber2017-09-121-2/+7
| | | | | | | | The BSP_output_char should output a char and not mingle with high level processing, e.g. '\n' to '\r\n' translation. Move this translation to rtems_putc(). Remove it from all the BSP_output_char implementations. Close #3122.
* Make rtems/print.h independent of rtems/bspIo.hSebastian Huber2016-06-221-12/+0
* Rename and move RTEMS_PRINTF_ATTRIBUTE()Sebastian Huber2016-06-221-12/+5
| | | | | Rename RTEMS_PRINTF_ATTRIBUTE() into RTEMS_PRINTFLIKE() (similar to <sys/cdefs.h> __printflike()) and move it to <rtems/score/basedefs.h>.
* Make rtems_fprintf_plugin() staticSebastian Huber2016-06-221-13/+0
* Make rtems_printf_plugin() staticSebastian Huber2016-06-221-13/+0
* Make printk_plugin() staticSebastian Huber2016-06-221-10/+0
* Fix rtems_print_printer_fprintf()Sebastian Huber2016-05-311-2/+15
| | | | We must use vfprintf().
* cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns2016-05-251-10/+23
| | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
* cpukit/include/rtems/bspIo.h: Add Doxygen commentsJoel Sherrill2015-03-111-29/+107
* Header File Doxygen Enhancement Task #2Mathew Kallada2012-12-281-0/+2
* libcsupport: Add and use rtems_putc()Sebastian Huber2012-08-201-0/+1
| | | | This reduces code size and provides a function similar to fputc().
* libcsupport: Add rtems_printf_plugin()Sebastian Huber2012-06-041-0/+2
* 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-241-4/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen.
* 2011-01-28 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-01-281-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h, score/cpu/i386/rtems/score/idtr.h, score/cpu/powerpc/rtems/powerpc/registers.h, score/src/objectidtoname.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/thread.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadclose.c, score/src/threadcreateidle.c, score/src/threaddelayended.c, score/src/threaddispatch.c, score/src/threadget.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadready.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadresume.c, score/src/threadsetpriority.c, score/src/threadsetstate.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/threadstart.c, score/src/threadstartmultitasking.c, score/src/threadsuspend.c, score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c: Fix typo where license said found in found in.
* Whitespace removal.Ralf Corsepius2009-11-291-1/+1
* 2009-06-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-06-161-0/+1
| | | | | * include/rtems/bspIo.h, libcsupport/Makefile.am: Add putk(). * libcsupport/src/putk.c: New file.
* 2008-09-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-221-1/+12
| | | | | | * include/rtems/bspIo.h, libcsupport/Makefile.am: Add genchark() for polled debug input from the same device as printk(). * libcsupport/src/getchark.c: New file.
* 2007-09-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-09-061-2/+19
| | | | | | | | | | | | | | | | * libcsupport/Makefile.am, libcsupport/src/printk.c: * libcsupport/src/printk_plugin.c: New file. include/rtems/bspIo.h, libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuuse.h, libmisc/stackchk/check.c, libmisc/stackchk/stackchk.h: rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemonreportstatistics.c: Added capability to specify your own "printf" routine to various reporting functions. This added an XXX_with_plugin as the underlying implementation for + rtems_rate_monotonic_report_statistics + rtems_stack_checker_report_usage + rtems_cpu_usage_report As demonstration, the http netdemo can now print out stack and cpu usage reports.
* 2007-07-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-07-261-0/+8
| | | | | | * include/rtems/bspIo.h, include/rtems/pci.h: Add extern "C" guards. Reported by Robert S. Grimes <rsg@alum.mit.edu>.
* New header guards.Ralf Corsepius2005-01-281-2/+2
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | * include/rtems/bspIo.h, include/rtems/fs.h, include/rtems/userenv.h: URL for license changed.
* Add vprintk function for kernel printing from routinesEric Norum2002-10-301-0/+2
| | | | which have already obtained the va_list pointer.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-081-5/+5
| | | | * include/rtems/bspIo.h: Fix cpp-guards, remove references to i386.
* Added printk as a generic, shared routine.Joel Sherrill2000-06-121-0/+37
