* include/rtems/bspIo.h, libcsupport/Makefile.am: Add genchark() for
polled debug input from the same device as printk().
* libcsupport/src/getchark.c: New file.
* libcsupport/Makefile.am, libcsupport/src/printk.c:
* libcsupport/src/printk_plugin.c: New file.
include/rtems/bspIo.h, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuuse.h, libmisc/stackchk/check.c,
libmisc/stackchk/stackchk.h: rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemonreportstatistics.c: Added capability to specify
your own "printf" routine to various reporting functions. This
added an XXX_with_plugin as the underlying implementation for
+ rtems_rate_monotonic_report_statistics
+ rtems_stack_checker_report_usage
+ rtems_cpu_usage_report
As demonstration, the http netdemo can now print out stack
and cpu usage reports.
* include/rtems/bspIo.h, include/rtems/pci.h:
Add extern "C" guards. Reported by
Robert S. Grimes <rsg@alum.mit.edu>.
* include/rtems/bspIo.h, include/rtems/fs.h, include/rtems/userenv.h:
URL for license changed.
which have already obtained the va_list pointer.
* include/rtems/bspIo.h: Fix cpp-guards, remove references to i386.
