2019-04-04 | doxygen: Added further groups to RTEMSAPI | Andreas Dachsberger | 1 | -9/+16 | |
Update #3706. Associativity Routines, BSD Compatibility Support now part of RTEMSAPI | |||||
2019-02-28 | Remove explicit file names from @file | Sebastian Huber | 1 | -1/+1 | |
This makes the @file documentation independent of the actual file name. Update #3707. | |||||
2018-01-25 | Remove make preinstall | Chris Johns | 1 | -0/+0 | |
A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254. | |||||
2017-01-12 | Fix documentation comment | Sebastian Huber | 1 | -4/+4 | |
2017-01-12 | Add and use rtems_assoc_thread_states_to_string() | Sebastian Huber | 1 | -0/+16 | |
2017-01-12 | Add rtems_assoc_32_to_string() | Sebastian Huber | 1 | -1/+32 | |
2012-12-28 | Header File Doxygen Enhancement Task #7 | Mathew Kallada | 1 | -1/+3 | |
2012-12-28 | Miscellaneous Doxygen clean-up | Joel Sherrill | 1 | -1/+1 | |
2012-12-15 | libcsupport: Doxygen Enhancement Task #8 | Alex Ivanov | 1 | -0/+3 | |
http://www.google-melange.com/gci/task/view/google/gci2012/7996208 | |||||
2012-12-11 | libcsupport: Doxygen enhancement GCI task #6 | Alex Ivanov | 1 | -4/+11 | |
http://www.google-melange.com/gci/task/view/google/gci2012/7992212 | |||||
2012-12-11 | libcsupport: Doxygen enhancement GCI task #4 | Alex Ivanov | 1 | -0/+3 | |
http://www.google-melange.com/gci/task/view/google/gci2012/8009205 | |||||
2012-12-11 | libcsupport: GCI Doxygen Task #7 | Alex Ivanov | 1 | -0/+3 | |
http://www.google-melange.com/gci/task/view/google/gci2012/7975223 | |||||
2012-12-10 | libcsupport: Doxygen enhancement task #5 | Alex Ivanov | 1 | -0/+6 | |
http://www.google-melange.com/gci/task/view/google/gci2012/7992211 | |||||
2012-12-09 | libcsupport: Doxygen enhancement task #2 | Alex Ivanov | 1 | -0/+6 | |
http://www.google-melange.com/gci/task/view/google/gci2012/8017203 | |||||
2012-12-08 | libcsupport: Doxygen Enhancement Task #3 | Mathew Kallada | 1 | -1/+13 | |
http://www.google-melange.com/gci/task/view/google/gci2012/7992210 | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-06-24 | 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -5/+3 | |
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen. | |||||
2009-06-03 | Add extern "C" {} guards. | Ralf Corsepius | 1 | -1/+10 | |
2008-01-25 | 2008-01-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -6/+6 | |
* libcsupport/include/rtems/assoc.h: rtems_assoc_ptr_by_local should be in public API. | |||||
2007-12-21 | 2007-12-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -8/+5 | |
PR 1268/cpukit * libcsupport/include/rtems/assoc.h: There is no rtems_assoc_ptr_by_value method. | |||||
2007-03-26 | 2007-03-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -15/+83 | |
* libcsupport/include/rtems/assoc.h: Pick up the include file changes associated with the file splitting. | |||||
2005-01-28 | New header guards. | Ralf Corsepius | 1 | -2/+2 | |
2004-12-02 | Add doxygen preamble. | Ralf Corsepius | 1 | -0/+4 | |
2004-03-23 | 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -16/+16 | |
* libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/ringbuf.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c, libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c, libcsupport/src/error.c, libcsupport/src/libio.c, libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c, libcsupport/src/no_libc.c, libcsupport/src/termios.c, libcsupport/src/termiosreserveresources.c: Convert to using c99 fixed-size types. | |||||
1996-04-22 | updates from Tony Bennett | Joel Sherrill | 1 | -2/+0 | |
1996-01-15 | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1 | -17/+17 | |
1995-08-17 | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1 | -0/+44 | |
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables |
