Improve file header comment.
Update #3993.
Change license to BSD-2-Clause according to file history and
documentation re-licensing agreement.
Update #3053.
Update #3899.
Update #3993.
Move multiprocessing related definitions to <rtems/rtems/mp.h>. This
makes <rtems.h> an include only header file.
Move type related definition to <rtems/rtems/types.h>. The goal is to
make <rtems.h> an include only header file.
Move task related declarations and definitions to <rtems/rtems/tasks.h>.
The goal is to make <rtems.h> an include only header file.
Move object related declarations and definitions to
<rtems/rtems/object.h>. The goal is to make <rtems.h> an include only
header file.
Move configuration related declarations and definitions to
<rtems/config.h>. The goal is to make <rtems.h> an include only header
file.
Close #3980.
Update #3973.
Update #3732.
Update #3706.
Update #3598.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
