This patch changes the license to BSD-2 for all source files where the
copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
Some files also includes copyright right statements from OAR and/or
embedded Brains in addition to Gaisler.
Updates #3053.
This file had no header, copyright, or license. Based on git history,
added appropriate copyright and license.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Interrupts have not been test yet
