line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This is in line with the FreeBSD and OpenSSL prototypes. It helps to
avoid superfluous compiler warnings.
* libmd/md5.h: C++ compatibility.
* libmd/md5.h: Revert Sebastian's patch.
* libmd/md5.h: Define MD5_DIGEST_SIZE.
Tomasz only tested this on the mpc823.
The official site for the original source for this PPP implementation is:
ftp://cs.anu.edu.au/pub/software/ppp
NOTE: As of 11/30/1999, the current version of this source is 2.3.10.
