path: root/cpukit/include/machine (follow)
* Include <stdbool.h> in <machine/_kernel_types.h>Sebastian Huber2018-08-271-0/+2
| | | | | | The FreeBSD kernel started to use the bool type. Update #3472.
* Add FreeBSD kernel space header filesSebastian Huber2018-08-274-0/+365
| | | | | | | | Move the kernel space content of some Newlib provided header files to RTEMS and libbsd. This allows to use the Newlib provided header files with different FreeBSD baselines. Update #3472.
* Update FreeBSD kernel timespec supportSebastian Huber2018-08-231-12/+13
| | | | | | | | | | | | | | | | | | | | | | | | | | | | This change is based on the following FreeBSD commit: "Make timespecadd(3) and friends public The timespecadd(3) family of macros were imported from NetBSD back in r35029. However, they were initially guarded by #ifdef _KERNEL. In the meantime, we have grown at least 28 syscalls that use timespecs in some way, leading many programs both inside and outside of the base system to redefine those macros. It's better just to make the definitions public. Our kernel currently defines two-argument versions of timespecadd and timespecsub. NetBSD, OpenBSD, and FreeDesktop.org's libbsd, however, define three-argument versions. Solaris also defines a three-argument version, but only in its kernel. This revision changes our definition to match the common three-argument version. Bump _FreeBSD_version due to the breaking KPI change. Discussed with: cem, jilles, ian, bde Differential Revision: https://reviews.freebsd.org/D14725" To make the change public (outside #ifdef _KERNEL) it must be integrated in Newlib. Update #3472.
* Remove make preinstallChris Johns2018-01-255-0/+289
