Check if given address/FIB exists locally.
Reviewed by: melifaro
Differential revision: https://reviews.freebsd.org/D32913
The modification to the hash are already naturally locked by
in_control_sx. Convert the hash lists to CK lists. Remove the
in_ifaddr_rmlock. Assert the network epoch where necessary.
Most cases when the hash lookup is done the epoch is already entered.
Cover a few cases, that need entering the epoch, which mostly is
initial configuration of tunnel interfaces and multicast addresses.
Differential revision: https://reviews.freebsd.org/D32584
Current logic always selects an IFA of the same family from the
outgoing interfaces. In IPv4 over IPv6 setup there can be just
single non-127.0.0.1 ifa, attached to the loopback interface.
Create a separate rt_getifa_family() to handle entire ifa selection
for the IPv4 over IPv6.
Differential Revision: https://reviews.freebsd.org/D31868
MFC after: 1 week
These functions were added in 2001 and are currently unused.
copyinfrom() looks to have never been used. copyinstrfrom() was used
for two weeks before the code was refactored to remove it's sole use.
Reviewed by: brooks, kib
Obtained from: CheriBSD
Sponsored by: DARPA
Differential Revision: https://reviews.freebsd.org/D24928
Use the copyright notice of the associated header file from FreeBSD if the
kernel space header file contains a substantial amount of imported code.
These files had no header, copyright, or license. Based on git history,
added appropriate copyrights and licenses.
These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
Integrate parts of this commit:
This commit brings in a new refactored TCP stack
called Rack. Rack includes the following features: - A different SACK
processing scheme (the old sack structures are not used). - RACK (Recent
acknowledgment) where counting dup-acks is no longer done instead time
is used to knwo when to retransmit. (see the I-D) - TLP (Tail Loss
Probe) where we will probe for tail-losses to attempt to try not to take
a retransmit time-out. (see the I-D) - Burst mitigation using TCPHTPS -
PRR (partial rate reduction) see the RFC.
Once built into your kernel, you can select this stack by either
socket option with the name of the stack is "rack" or by setting
the global sysctl so the default is rack.
Note that any connection that does not support SACK will be kicked
back to the "default" base FreeBSD stack (currently known as "default").
To build this into your kernel you will need to enable in your
kernel:
makeoptions WITH_EXTRA_TCP_STACKS=1
options TCPHPTS
Sponsored by: Netflix Inc.
Differential Revision: https://reviews.freebsd.org/D15525
The FreeBSD kernel started to use the bool type.
Update #3472.
Move the kernel space content of some Newlib provided header files to
RTEMS and libbsd. This allows to use the Newlib provided header files
with different FreeBSD baselines.
Update #3472.
This change is based on the following FreeBSD commit:
"Make timespecadd(3) and friends public
The timespecadd(3) family of macros were imported from NetBSD back in
r35029. However, they were initially guarded by #ifdef _KERNEL. In the
meantime, we have grown at least 28 syscalls that use timespecs in some
way, leading many programs both inside and outside of the base system to
redefine those macros. It's better just to make the definitions public.
Our kernel currently defines two-argument versions of timespecadd and
timespecsub. NetBSD, OpenBSD, and FreeDesktop.org's libbsd, however, define
three-argument versions. Solaris also defines a three-argument version, but
only in its kernel. This revision changes our definition to match the
common three-argument version.
Bump _FreeBSD_version due to the breaking KPI change.
Discussed with: cem, jilles, ian, bde
Differential Revision: https://reviews.freebsd.org/D14725"
To make the change public (outside #ifdef _KERNEL) it must be integrated
in Newlib.
Update #3472.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
